[Qgis-developer] Import error in the qgis.core, qgis.guimodule, Help needed
Marco Pasetti marcopstt at gmail.com
Fri Sep 5 10:10:02 EDT 2008
Hi Bishwarup,
> I did the same way u suggested i still get the following error
>>>> import sys
>>>> sys.path
> ['F:\\Python25\\Lib\\idlelib', 'C:\\WINNT\\system32\\python25.zip',
> 'F:\\Python25\\DLLs', 'F:\\Python25\\lib', 'F:\\Python25\\lib\\plat-win',
> 'F:\\Python25\\lib\\lib-tk', 'F:\\Python25',
> 'F:\\Python25\\lib\\site-packages']
>>>> import qgis.core
> Traceback (most recent call last):
>  File "<pyshell#2>", line 1, in <module>
>    import qgis.core
> ImportError: DLL load failed: The specified module could not be found.
> Second portion
>>>> sys.path
>>>> import gqis.core
>  File "<pyshell#4>", line 1, in <module>
>    import gqis.core
> ImportError: No module named gqis.core
>>>> from qgis.core import *
>  File "<pyshell#5>", line 1, in <module>
> The first portion of the error when i copied the qgis dir inside site
> package.
> The second portion of error is when i added the pythonpath variable.
> I have installed python in my F: drive
> as F:\python25
> and Quantum GIS 0.11.0.2 in F:\Quantum GIS.
Where is your python script? I suggest you to put it into F:\Quantum
GIS\python\plugins
The Python and PyQt libraries bundled within qgis 0.11.0-x are: Python 2.5.2
and PyQt 4.4.2
Different Python and PyQt version installed libraries may cause errors if
the python script is launched outside the qgis tree (dir and subdirs)
Regards,
Marco
