[Qgis-developer] My introduction and 1st question
Martin Weis martin.weis.newsadress at gmx.de
Sat Sep 6 09:29:39 EDT 2008
Hello Stefan!
Stefan Sassenberg wrote:
> I checked out qgis with "svn co https://svn.osgeo.org/qgis/trunk/qgis
> qgis" and configured it successfully. "Making" the current state is yet
> not possible, because of an error:
> /home/stefan/cprg/workspace/qgis/src/core/qgsgeometry.cpp: In member
> function »int QgsGeometry::splitLinearGeometry(GEOSGeom_t*,
> QList<QgsGeometry*>&)«:
> /home/stefan/cprg/workspace/qgis/src/core/qgsgeometry.cpp:4602: Fehler:
> »GEOSLength« wurde in diesem Gültigkeitsbereich nicht definiert
Is this the first line? Or are there some before, e.g. could not find
somefile.h?
Have you installed (recent version of) libgeos-dev? On my debian there are:
ii  libgeos-3.0.0                        3.0.0-5
Geometry engine for Geographic Information Systems - C+
ii  libgeos-c1                           3.0.0-5
ii  libgeos-dev                          3.0.0-5
Geometry engine for GIS - Development files
To get english messages you can use
LANG=C make
You can also have a look, if the ccmake found the correct
GEOS_INCLUDE_DIR etc., try geos-config --cflags
Good luck,
Martin Weis
PGP-Key: http://datenroulette.de/pgp.php
Desc: OpenPGP digital signature
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080906/22082275/signature.bin
