[Qgis-developer] Re: Access raster data from python plugins
Ghislain Picard ghislain.picard at lgge.obs.ujf-grenoble.fr
Sun Sep 7 09:15:00 EDT 2008
Following the idea in my last email. I propose a function getValue in
QgsRatserLayer before API freezing. More efficient than identify to
retrieve value (return double instead of string) in a single band.
The same kind of function to return a piece of raster would be
interesting too.
Regards,
Ghislain
double QgsRasterLayer::getValue(const QgsPoint& point, int iband)
   double x = point.x();
   double y = point.y();
   QgsDebugMsg( QString::number( x ) + ", " + QString::number( y ) );
   if ( x < mLayerExtent.xMin() || x > mLayerExtent.xMax() || y <
mLayerExtent.yMin() || y > mLayerExtent.yMax() )
     return nan();
   else
     /* Calculate the row / column where the point falls */
     double xres = ( mLayerExtent.xMax() - mLayerExtent.xMin() ) /
mRasterXDim;
     double yres = ( mLayerExtent.yMax() - mLayerExtent.yMin() ) /
mRasterYDim;
     // Offset, not the cell index -> flor
     int col = ( int ) floor(( x - mLayerExtent.xMin() ) / xres );
     int row = ( int ) floor(( mLayerExtent.yMax() - y ) / yres );
     QgsDebugMsg( "row = " + QString::number( row ) + " col = " +
QString::number( col ) );
     GDALRasterBandH gdalBand = GDALGetRasterBand( mGdalDataset, iband );
     GDALDataType type = GDALGetRasterDataType( gdalBand );
     int size = GDALGetDataTypeSize( type ) / 8;
     void *data = CPLMalloc( size );
     CPLErr err = GDALRasterIO( gdalBand, GF_Read, col, row, 1, 1,
			       data, 1, 1, type, 0, 0 );
     if ( err != CPLE_None )
         QgsLogger::warning( "RaterIO error: " + QString(
CPLGetLastErrorMsg() ) );
     double value = readValue( data, type, 0 );
#ifdef QGISDEBUG
     QgsLogger::debug( "value", value, 1, __FILE__, __FUNCTION__,
__LINE__ );
#endif
     if ( mValidNoDataValue && ( mNoDataValue == value || value != value ) )
	return nan();
     free( data );
     return value;
} // void QgsRasterLayer::getValue
Ghislain Picard wrote:
> Hi,
> I'd like to access large part of the raster dataset to build scattergram
> from two raster layers.
> Is there any mean to access raster data from python plugins more
> efficiently than with the QgsRasterLayer::identify method ?
> A version of identify that return a single band would be interesting too.
> Finally what do you thing of a public access to mGDALDataset ?
> Cheers,
> Ghislain
> P.S. new on the list. Aims at enhancing qgis for the analysis of remote
> sensing images.
