[Qgis-developer] compiling 1.0
Paolo Cavallini cavallini at faunalia.it
Tue Sep 9 03:38:19 EDT 2008
Jürgen E. Fischer ha scritto:
> Do you have the -dev packages installed?  If so, you need to remove them
> first, otherwise the fresh build will pickup the old header files.
> BTW you can also build debian packages by running
> 	dpkg-buildpackage -us -uc -b
Thanks a lot Jurgen! Installing as root (with debs) solved all.
Perhaps this should be documented in the INSTALL file?
All the best.
pc
Paolo Cavallini, see: * http://www.faunalia.it/pc *
