[Qgis-developer] Re: QGISwindows build - Alaska dataset
Marco Pasetti marcopstt at gmail.com
Wed Sep 17 03:41:45 EDT 2008
Hi all,
> OK, I guess we will hear about it if there are any side-effects of this
> change.
> The new sample dataset does have GRASS data in it, as well as a number of
> formats that were not represented in the old dataset.
> The idea is to have all the data share a common location (Alaska) so we
> can combine them for examples such as demonstrating on-the-fly projection
> and such.
fixed in trunk at rev 9340 (http://trac.osgeo.org/qgis/changeset/9340)
I needed to modify the size properties of the new dataset, because the
script (unfortunately) cannot read by itself neither the size of the tar.gz
file nor the size of the unpacked folder.
Marco
