[Qgis-developer] segfault
Paolo Cavallini cavallini at faunalia.it
Fri Sep 26 13:56:15 EDT 2008
Peter Ersts ha scritto:
> otherwise it will build the result string(s) and return true. It would
> be good if you could try again with revision 9414 and see if it still
> crashes -- the plugin may indeed still need to be updated.
Hi Peter,
thanks for this. Will do ASAP, probably on Monday.
All the best.
pc
Paolo Cavallini, see: * http://www.faunalia.it/pc *
