[Qgis-developer] Mac Xcode config changes
William Kyngesburye woklist at kyngchaos.com
Wed Apr 15 23:43:50 EDT 2009
I have the default PYTHON_FORM set as 'fw', which means the python.org
framework, because I don't know if there is a setting with build
system (so I can set PYTHON_FORM dynamically).  It's probably there
somewhere, I just need to look harder.
You need to set the PYTHON_FORM to system to use the Leopard Python.
No need to hack the source.
On Apr 15, 2009, at 10:04 PM, John C. Tull wrote:
> William,
> I'm back to testing your Xcode project. I agree with other folks
> that this is a great and valuable addition to qgis.
> Using the stock template on my 10.5 machine with your frameworks and
> nothing else non-stock, plus qt-4.5 (not 4.4), I have run into a
> couple of problems.
> For some reason, an include in qgspythonutilsimpl.cpp is not getting
> picked up:
> #include <Python.h>
> fails to be found. If I add the full path to Python.h as:
> #include </System/Library/Frameworks/Python.framework/Versions/2.5/
> include/python2.5/Python.h>
> I run into a new error:
> /Users/jctull/sources/qgis/trunk/mac/xcode/build/native/Qgis.build/
> Release/python_modules.build/Script-7256F1530F4105770022BE1F.sh:
> line 40: /Library/Frameworks/Python.framework/Versions/2.5/bin/
> python: No such file or directory
> I'm unclear as to why it is looking in /Library... when it should
> be /System/Library...
> That is the state of things for me right now.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian]  What are you supposed to do WITH a maniacally depressed
robot?
[Marvin]  You think you have problems?  What are you supposed to do if
you ARE a maniacally depressed robot?  No, don't try and answer, I'm
50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
