[Qgis-developer] Help needed in creating Third Level Submenu
Bishwarup Banerjee
bishwarup.banerjee at gmail.com
Tue Aug 4 01:14:43 EDT 2009
Hi German,
Thank you very much for your reply. I will try to incorporate the way you
suggested. But, I thing I was wondering is that if "addActions" does not
inherits from QAction, then how is that when I go to only second level of
submenu option, instead of thrird level, it works fine. The problem arises
only when we go to the third level.
With warm Regards,
Bishwarup
2009/8/3 Germán Carrillo <carrillo.german at gmail.com>
> Hi Bishwarup, the addActions method is in QWidget class, and QAction don't
> inherited from that. So addActions don't exist for QAction. Maybe you can
> use QtDesigner to create the menu level you want and then generate the .py
> with pyuirc4, this way you can see how to create it.
> Why you don't use the last QGis version?
> Germán
> 2009/8/3 Bishwarup Banerjee <bishwarup.banerjee at gmail.com>
>> Dear All,
>> I am trying to create THIRD LEVEL MENU through the following code. Like I
>> have a menu Called "Boundaries", inside that I have sub menu called
>> "Division", inside that I have "Division_name", inside "Division Name" we
>> have a separate sub menu called "Division Range", on clicking on the sub
>> menu "Division range" some action is done, like opening the range boundary
>> shape file. I am able to open the Shape file portion, but I am getting error
>> in the Bold Line marked as "AttributeError: addActions"
>> self.menu = QMenu()
>> self.menu.setTitle( "Boundaries" )
>> self.DM = QMenu( "Division" )
>> self.Div1 = QAction( QIcon( ":/icons/find.png" ), "Division
>> Name",self.iface.getMainWindow() )
>> self.DM.addActions( [ self.Div1])
>> self.menu.addMenu( self.DM )
>> menuBar = self.iface.getMainWindow().menuBar()
>> menuBar.addMenu(self.menu)
>> self.Div_Range = QAction( QIcon( ":/icons/find.png" ), "Division
>> Range",self.iface.getMainWindow() )
>> *self.Div1.addActions( [ self.Div_Range])*
>> self.menu.addMenu( self.Div_Range )
>> QObject.connect( self.Div_Range, SIGNAL("triggered()"),
>> self.Div1_Clicked )
>> It will be of immense help, if anybody can point the error in the code, or
>> is it like THIRD LEVEL SUBMENU is not supported in QGIS?
>> I am using QGIS 0.11, Python 2.5 and QT.
>> I am posting the same in the QGIS Developer forum
>> Thanking you in advance,
>> With Warm Regards
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> |\__
> (:>__)(
> Soluciones Geoinformáticas Libres
> http://geotux.tuxfamily.org/
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090804/2aedaebe/attachment.html
