[Qgis-developer] problem restarting plugin
    Chang, Elizabeth
    Elizabeth.Chang at noblis.org
    Wed Aug 12 09:52:40 EDT 2009
I have a plugin that works fine the first time you run it. Then, when
you try to restart the plugin, I get this error:
  File "C:/Documents and
Settings/m29308/.qgis//python/plugins\NoblisPostGISGraphs\NoblisPostGISG
raphs.py", line 42, in run
    QObject.connect(self.PostGISdialog, SIGNAL("Graph"), self.graph)
TypeError: argument 3 of QObject.connect() has an invalid type
Python version:
2.5.2 (r252:60911, Feb 21 2008, 13:11:45) [MSC v.1310 32 bit (Intel)]
I can't figure out why it is complaining about argument 3-self.graph is
a method name and not only does it work the first time around, other
connections are also fine. The only difference is that self.graph takes
in a list.
In PostGISdialog
                @pyqtSignature("on_GraphButton_clicked()")
                def on_GraphButton_clicked(self):
                                tables=[]
                                for index in
xrange(self.GraphListWidget.count()):
tables.append(str(self.GraphListWidget.item(index).text()))
                                self.emit(SIGNAL("Graph(QStringList)"),
QStringList(tables))
in PostGISGraphs
                def run(self):
                                QObject.connect(self.canvas,
SIGNAL("selectionChanged(QgsMapLayer*)"), self.selectionchanged)
                                flags = Qt.WindowTitleHint |
Qt.WindowSystemMenuHint | Qt.WindowMaximizeButtonHint     #
QgisGui.ModalDialogFlags
                                self.PostGISdialog=
PostGISdialog(self.iface.mainWindow(), flags)
SIGNAL("LoadScript(QString)"), self.loadscript)
SIGNAL("ExportScript(QString, QString)"), self.exportscript)
SIGNAL("Graph(QStringList)"),self.graph)
SIGNAL("Execute(QString)"), self.execute)
SIGNAL("SaveConn(QString)"), self.saveConnection)
SIGNAL("Connect(QString)"), self.establishConnection)
SIGNAL("Disconnect(QString)"), self.disconnectdb)
SIGNAL("GetTablesFromSchema(QString)"), self.populateTables)
                                self.PostGISdialog.show()
                def graph(self, tablesToGraph):
                                self.tablesToGraph=list(tablesToGraph)
Does anyone have any ideas? Thanks in advance.
Elizabeth Chang
Lead
Noblis
3150 Fairview Park Drive Sourth
Falls Church, VA 22042
703-610-2321 (office)
elizabeth.chang at noblis.org
Noblis
For the best of reasons
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090812/02f07109/attachment-0001.html
