[Qgis-developer] Re: symbology-ng build
John C. Tull jctull at gmail.com
Mon Aug 17 20:12:03 EDT 2009
That seems to have worked and things are getting farther:
Creating qgisconfig.py...
Done
[ 60%] Generating core/core.so
/System/Library/Frameworks/Python.framework/Versions/2.5/share/sip/
PyQt4/QtCore/qlist.sip: In function ‘int
convertTo_QList_27000600QList_0200QgsSymbolV2LevelItem(PyObject*,
void**, int*, PyObject*)’:
PyQt4/QtCore/qlist.sip:85: error: ‘sipType_QgsSymbolV2Level’ was not
declared in this scope
PyQt4/QtCore/qlist.sip:103: error: ‘sipType_QgsSymbolV2Level’ was not
PyQt4/QtCore/qlist.sip: In function ‘PyObject*
convertFrom_QList_27000600QList_0200QgsSymbolV2LevelItem(void*,
PyObject*)’:
PyQt4/QtCore/qlist.sip:59: error: ‘sipType_QgsSymbolV2Level’ was not
make[3]: *** [sipcoreQList.o] Error 1
make[2]: *** [python/core/core.so] Error 2
make[1]: *** [python/CMakeFiles/python.dir/all] Error 2
make: *** [all] Error 2
Thanks,
John
On Aug 17, 2009, at 4:44 PM, Martin Dobias wrote:
> On Tue, Aug 18, 2009 at 1:02 AM, John C. Tull<jctull at gmail.com> wrote:
>> Martin,
>> I thought I'd check in on your progress today, but was unable to
>> successfully build the symbology-ng branch. I'm not sure if you are
>> ready
>> for testing, but here is the error:
>> [ 17%] Building CXX object src/core/CMakeFiles/qgis_core.dir/pal/
>> feature.o
>> /Users/jctull/sources/qgis/symbology-ng-branch/src/core/pal/
>> feature.h:57:
>> error: ‘ushort’ does not name a type
> Hi John,
> try r11420, it should have this error fixed.
> Martin
