[Qgis-developer] QgsVectorLayer Failed To load
Germán Carrillo carrillo.german at gmail.com
Wed Dec 23 09:17:49 EST 2009
I'm not sure. I do use this to set the qgis_prefix:
*    if os.name == "nt":
        osgeo4wDir = "C:/OSGeo4W/apps/qgis-1.3"
        basicDir = "C:/qgis"
        if os.path.isdir( osgeo4wDir ):
            qgis_prefix = osgeo4wDir
        else:
            qgis_prefix = basicDir
    else:
        qgis_prefix = "/usr"*
*    if not os.path.isdir( qgis_prefix ):
        raise RuntimeError, "QGIS dir not found!"*
Even better is to copy the plugins and resources dirs from QGIS installation
to your application dir. This way you can set the qgis_prefix to '.' .
(Tested on Windows)
Regards.
Germán
El 23 de diciembre de 2009 04:56, Luca Delucchi <lucadeluge at gmail.com>escribió:
> 2009/12/22 Germán Carrillo <carrillo.german at gmail.com>:
> > Hi Luca.
> > I guess you have troubles with qgis_prefix. You should set it to point
> the
> > QGIS dir.
> > e.g.   qgis_prefix = '/usr'     (On Ubuntu it works)
> thank's i solved it.
> Is possible to set it automatically?
> > Regards.
> > Germán
> Thank's
> Luca
  |\__
(:>__)(
Soluciones Geoinformáticas Libres
http://geotux.tuxfamily.org/
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20091223/8f2d5b71/attachment.html
