[Qgis-developer] roadmap
Marco Hugentobler marco.hugentobler at karto.baug.ethz.ch
Mon Feb 2 03:01:03 EST 2009
Hi Florian,
I saw QGIS printing in formats >A4 on an A0 plotter.
I suppose that your problem with A3 is not related to QGIS but rather to your
printer setup and the Qt printing system. Maybe it also helps to look at the
printing dialog carefully as there are usually several places to set the paper
format.
Regards,
Marco
Am Mittwoch 28 Januar 2009 17:01:24 schrieb Florian Lohoff:
> On Wed, Jan 28, 2009 at 08:32:48AM +0100, Andreas Neumann wrote:
> > in addition to Paolos ideas there could be improvements in the following
> > areas:
> > * printing improvements (printing big rasters, grid lines/graticules in
> > print composer) - its probably mainly Marco Hugentobler, who is working
> > on it
> I fail to print on anything else than A4 - If printing on A3 i get a A3
> paper but the output is of size A4 centered on the A3. The page also
> does not display the full output seen in the print composer but only the
> A4 portion at the top left.
> Currently i print everything A4 into a PDF and then print it with
> acroread to A3 - Takes a lot of time for a simple print ...
> At least the 1.0 does not crash on me every 2nd print ...
> Flo
Dr. Marco Hugentobler
Institute of Cartography
ETH Zurich
Technical Advisor QGIS Project Steering Committee
