[Qgis-developer] proxy
Marco Hugentobler marco.hugentobler at karto.baug.ethz.ch
Wed Feb 4 09:08:52 EST 2009
>Can the diagram branch be considered stable?
Nearly. I still need to implement loading/saving of the diagrams from project
files. The second problem is that the PAL library for placement needs geos3.
Either we set the minimum requirement for geos to 3 or we try to insert some
macros similar to what has been done in QgsGeometry (but that is a bit ugly).
Regards,
Marco
Am Mittwoch 04 Februar 2009 15:03:53 schrieb Paolo Cavallini:
> Marco Hugentobler ha scritto:
> > Hi Paolo
> > Proxy support should work for 1.1. At least I have positive feedback from
> > the proxy user that tested.
> > It is even possible to give strings of urls that don't go through the
> > proxy. Every request starting with such an url string is then excluded
> > from proxy settings. This feature already works for WMS and WFS and
> > plugin installer will follow soon.
> > Postgis request have no proxy support yet.
> Good news. BTW, what about releasing 1.0.1? I think several bugs have
> already been fixed. Can the diagram branch be considered stable?
> All the best.
> pc
Dr. Marco Hugentobler
Institute of Cartography
ETH Zurich
Technical Advisor QGIS Project Steering Committee
