[Qgis-developer] Open vector dialog
Tim Sutton tim at linfiniti.com
Thu Feb 5 00:02:37 EST 2009
Hi Godofredo
On Wednesday 04 February 2009 21:41:30 godofredo contreras wrote:
> Hi developers:
> I've been working in a replacement for open vector dialog. The ideas behind
> this work are:
>  support multilayer formats
>  support more ogr formats
>  support for opening database layers
>  support of service layers
> To reach this goal I started classifying the ogr drivers as:
>  File based
>  Directory based
>  Database based
>  Service based
This sounds like a good classification - perhaps Frank or others have more
thoughts on this,
> There are a lot of formats in ogr and the question that come to my
> mind is should qgis support as many formats as there are in ogr or
> choose just some of them? in the other hand there are some drivers
> for formats I don`t know and I'm not sure if I classified them correctly
> and if I set the file filters correctly.
My personal feeling is that if we can open every supported format that the
particular OGR/GDAL on the users machine was compiled with it would be first
prize.
> Attached is doc file with the classification and the "yes"
> in column "qgis supported" means I have opened layers of that format.
> Any fixes to classification list are welcome as well as any comment.
In the few minutes I had to look at your list you classification seemed right
to me. Does this imply we will need to create a programmatic master list for
QGIS to read and associate with GDAL formats? Perhaps indicating wich category
the format fits into would be something Frank would consider adding to the next
iteration of GDAL/OGR so that we always have a current classification list
regardless of which >= current  version of gdal the user has.
I'm really looking forward to your patch!
Regards
Tim
> Regards
> Godofredo Contreras
> _________________________________________________________________
> Windows Live™: Keep your life in sync.
> http://windowslive.com/howitworks?ocid=TXT_TAGLM_WL_t1_allup_howitworks_022
>009
Name: not available
Desc: This is a digitally signed message part.
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090205/c36d73b7/attachment-0001.bin
