[Qgis-developer] Unable to import qgis.core on OS X
William Kyngesburye woklist at kyngchaos.com
Sat Feb 7 00:53:09 EST 2009
Relinked Qgis Leopard is now online.
On Feb 6, 2009, at 4:47 PM, William Kyngesburye wrote:
> Oh damn, I accidentally linked Qgis to a dev copy of GEOS.
> Suggestion: wait until I package a correctly linked Qgis.
> Hmmm, I wonder if that's why I had the Python problem with the Tiger
> Qgis build, which I fixed by building it on Tiger - and with a
> release version of my GEOS framework ;)
> On Feb 6, 2009, at 4:15 PM, Gary Sherman wrote:
>> Trying to import qgis.core on OS X Leopard, Framework install from
>> KyngChaos.com:
>> ImportError: dlopen(/Applications/Qgis.app/Contents/MacOS/share/
>> qgis/python/qgis/core.so, 2): Symbol not found:
>> _GEOSPolygonizer_getCutEdges
>> Referenced from: /Applications/Qgis.app/Contents/MacOS/share/qgis/
>> python/qgis/../../../../lib/libqgis_core.dylib
>> Expected in: /Library/Frameworks/GEOS.framework/Versions/3/GEOS
>> Any suggestions?
>> -gary
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian]  What are you supposed to do WITH a maniacally depressed
robot?
[Marvin]  You think you have problems?  What are you supposed to do if
you ARE a maniacally depressed robot?  No, don't try and answer, I'm
50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
