[Qgis-developer] Re: Two weeks to get QGIS into the next, Ubuntu 9.04 release
Agustin Lobo Agustin.Lobo at ija.csic.es
Sat Feb 7 08:18:15 EST 2009
Done. This issue has been discussed several times, not reaching any
practical solution though.
Agus
2009/2/7 Cameron Shorter <cameron.shorter at gmail.com>:
> Thanks for enlightening me Agustin,
> Do you mind CCing this email to the qgis list so that you (or I) can ask how
> people suggest this is solved for:
> 1. debiangis
> 2. ubuntugis
> 3. the liveDVD
> I suspect this might be a show stopper for Debian, but Ubuntu and the
> LiveDVD might be able to get around this.
> Agustin Lobo wrote:
>> Cameron
>> I've seen your message to the QGIS dev list.
>> Just wanted to let you know my opinion that a major problem of the
>> current QGIS binaries for ubuntu is that they lack support
>> for ECW and MrSid raster formats. This has been accomplished for
>> the windows osgeo4w distribution, so I guess that similar solutions to
>> solve licensing issues should exist (i.e., even if the qgis binaries
>> cannot include support for these formats, the qgis installation could
>> contemplate the possibility of adding support for these formats
>> through an independent, subsequent installation) .
>> Many raster layers provided by cartographic institutions are in either
>> ecw or MrSid format, including the extensive Landsat archive in
>> https://zulu.ssc.nasa.gov/mrsid/
>> Not having support for these formats is enough for many potential users to
>> actually not using qgis under linux.
>> Thanks
>> Agus
> Cameron Shorter
> Geospatial Systems Architect
> Tel: +61 (0)2 8570 5050
> Mob: +61 (0)419 142 254
> Think Globally, Fix Locally
> Geospatial Solutions enhanced with Open Standards and Open Source
> http://www.lisasoft.com
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
Lluis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
e-mail Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
