[Qgis-developer] Compiling tutorials on windows
Tim Sutton tim at linfiniti.com
Tue Feb 10 07:13:18 EST 2009
Hi
I dont have a windows dev environment to test on. But I suggest trying to use
cmakesetup - the cmake gui application to configure before trying to build. You
need to also have all the QGIS development libs and headers available.
If you do get it to build, please contribute your notes back to me so I can
incorporate them into the tutorial for the benifit of other win users.
Regards
Tim
On Monday 09 February 2009 11:52:45 Голубев Анатолий wrote:
> Hello, mailing list!
> I`m new in QGIS developing and trying to compile tutorials on windows.
> I`m checked sources from svn:
> svn co
> https://svn.osgeo.org/qgis/trunk/code_examples/1_hello_world_qgis_style
> cd 1_hello_world_qgis_style
> mkdir build
> cd build
> cmake ..
> And CMake prints some errors:
> CMake Error: CMake was unable to find a build program corresponding to
> "Visual Studio 6".  CMAKE_MAKE_PROGRAM is not set.  You probably need to
> select a different build tool.
> CMake Error: Could not find cmake module
> file:C:/dev/1_hello_world_qgis_style/build/CMakeFiles/CMakeCCompiler.cmake
> file:C:/dev/1_hello_world_qgis_style/build/CMakeFiles/CMakeCXXCompiler.cmak
>e CMake Warning (dev) in CMakeLists.txt:
>   No cmake_minimum_required command is present.  A line of code such as
>     cmake_minimum_required(VERSION 2.6)
>   should be added at the top of the file.  The version specified may be
> lower
>   if you wish to support older CMake versions for this project.  For more
>   information run "cmake --help-policy CMP0000".
> This warning is for project developers.  Use -Wno-dev to suppress it.
> -- Configuring incomplete, errors occurred!
> What should I do to compile this tutorial? I have MinGW, Qt4.4.3 and
> QGIS 1.0 installed
> Qgis-developer mailing list
Name: not available
Desc: This is a digitally signed message part.
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090210/d010ce88/attachment.bin
