[Qgis-developer] [Plugin] Added, deleted or changed features
in a layer
Tim Sutton
tim at linfiniti.com
Wed Jan 14 11:39:38 EST 2009
On Wed, 2009-01-14 at 00:01 +0100, Martin Dobias wrote:
> Hi Olivier
> On Sun, Jan 11, 2009 at 5:39 PM, Olivier Tournaire <olitour at gmail.com> wrote:
> >> Also dont forget the new methods should be added to the corresponding
> >> sip file so that they appear in python bindings!
> > OK. Is there only one file to change python/core/sipcoreQgsVectorLayer.cpp ?
> no, that's only a generated file. You'll need to modify
> python/core/qgsvectorlayer.sip. Usually one needs to only copy the
> definitions from .h file to appropriate .sip without more changes. If
> you need some more help, just ask...
Sorry I was a bit tired and didnt read that file name carefully enough!
Regards
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Visit http://linfiniti.com to find out about:
* QGIS programming services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting & Support Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090114/21c25ca7/attachment.bin
