[Qgis-developer] PostGIS manager
Jeremy Palmer JPalmer at linz.govt.nz
Thu Jan 15 16:01:44 EST 2009
Thanks that saves one more manual installation :)
Cheers,
Jeremy
-----Original Message-----
Sent: Friday, 16 January 2009 3:54 a.m.
To: Jeremy Palmer
Cc: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] PostGIS manager
Hi Jeremy,
On Thu, 15. Jan 2009 at 11:41:21 +1300, Jeremy Palmer wrote:
> FYI I've been running PostGIS manager v0.4.3 with OSGeo4W QGIS v1.0
> under WinXP SP2.
BTW OSGeo4W now also has pycopg2 and pyqwt5 available (for PostGIS manager
and the value tool plugins)
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
______________________________________________________________________________________________________
This message contains information, which is confidential and may be subject to legal privilege.
If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
Thank you.
