[Qgis-developer] Build plugins for use with Mac binary
Peter Ersts
ersts at amnh.org
Thu Jan 22 14:21:56 EST 2009
William Kyngesburye wrote:
> On Jan 21, 2009, at 1:38 PM, Peter Ersts wrote:
>> Sorry but it do not work. In order to get this build
>> (http://www.kyngchaos.com/files/software/unixport/Qgis-1.0.0-1-Leopard.dmg)
>> to run with this GDAL framework
>> (http://www.kyngchaos.com/files/software/unixport/GDAL_Framework-1.6.0-4.dmg)
>> I had to install this postgresql framework
>> (http://www.kyngchaos.com/files/software/unixport/PostgreSQL-8.3.5-1.dmg).
>> With out the postgres framework, your version of qgis would not
>> start, and when started from the command line this is what I got.
>> localhost:MacOS pete$ ./qgis
>> dyld: Library not loaded: /usr/local/pgsql/lib/libpq.5.dylib
>> Referenced from: /Library/Frameworks/GDAL.framework/Versions/1.6/GDAL
>> Reason: image not found
>> Trace/BPT trap
> Hmm, I can't find anything in the GDAL framework or Qgis.app that
> references /usr/local/pgsql/lib/libpq.5.dylib. libpq should be a
> relative reference, with @loader_path.
pete$ otool -L /Library/Frameworks/GDAL.framework/Versions/1.6/GDAL
/Library/Frameworks/GDAL.framework/Versions/1.6/GDAL:
/Library/Frameworks/GDAL.framework/Versions/1.6/GDAL (compatibility
version 15.0.0, current version 15.0.0)
/Library/Frameworks/PROJ.framework/Versions/4.6/PROJ (compatibility
version 6.0.0, current version 6.5.0)
/Library/Frameworks/GEOS.framework/Versions/3/GEOS (compatibility
version 4.0.0, current version 4.1.0)
/Library/Frameworks/SQLite3.framework/Versions/3/SQLite3 (compatibility
version 9.0.0, current version 9.6.0)
/usr/lib/libiodbc.2.dylib (compatibility version 4.0.0, current version
4.10.0)
/usr/lib/libiodbcinst.2.dylib (compatibility version 4.0.0, current
version 4.10.0)
/System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
(compatibility version 1.0.0, current version 18.0.0)
/Library/Frameworks/UnixImageIO.framework/Versions/B/UnixImageIO
(compatibility version 1.0.0, current version 1.0.26)
/Library/Frameworks/GDAL.framework/Versions/1.6/Libraries/libogdi.dylib
(compatibility version 0.0.0, current version 0.0.0)
/usr/local/pgsql/lib/libpq.5.dylib (compatibility version 5.0.0, current
version 5.1.0)
/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version
88.3.10)
/usr/lib/libxml2.2.dylib (compatibility version 9.0.0, current version
9.16.0)
/usr/lib/libicucore.A.dylib (compatibility version 1.0.0, current
version 32.0.0)
/usr/lib/libcurl.3.dylib (compatibility version 4.0.0, current version
4.0.0)
/usr/lib/libssl.0.9.7.dylib (compatibility version 0.9.7, current
version 0.9.7)
/usr/lib/libcrypto.0.9.7.dylib (compatibility version 0.9.7, current
version 0.9.7)
/usr/lib/libz.1.dylib (compatibility version 1.0.0, current version 1.2.3)
/usr/lib/libstdc++.6.dylib (compatibility version 7.0.0, current version
7.4.0)
/usr/lib/libgcc_s.1.dylib (compatibility version 1.0.0, current version
1.0.0)
/System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
(compatibility version 150.0.0, current version 368.33.0)
Peter J. Ersts, Project Specialist
American Museum of Natural History
Center for Biodiversity and Conservation
Central Park West at 79th Street
New York, New York 10024
Tel: Home Office (518)-632-4745 or NYC Office (212)-496-3488
Web: http://biodiversityinformatics.amnh.org
Web: http://cbc.amnh.org
Quantum GIS Raster Development Team. Visit http://www.qgis.org
to learn more about QGIS, a free and open source desktop GIS
Open Source,
...evolving through community cooperation to change the world bit by bit
