[Qgis-developer] New GeoCoding python plugin
Alessandro Pasotti apasotti at gmail.com
Wed Jun 3 13:24:54 EDT 2009
Hello,
I wrote a new GeoCoding python plugin that uses Google webservices, this
plugin is completely independent from the existing geocoding plugin written
by perrygeo (no shared code).
The plugin supports geocoding and reverse geocoding.
The plugin has an external dependency on geopy so I decided to include it in
the zip.
geopy has a dependency on simplejson (which has some C code, so I did'nt
include it in the zip).
I tested it locally but Paolo Cavallini reported a problem (which I wasn't
able to reproduce) with geopy dependency.
I would really appreciate you comments, impressions and  any help in fixing
the a.m. issue if you experience it.
The plugin is available at this repo:
http://elpaso.homelinux.org/qgis/plugins.xml
Thank you in advance!
Alessandro Pasotti
w3:   www.itopen.it
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090603/fca8c15e/attachment.html
