[Qgis-developer] undo/redo in trunk
Tim Sutton lists at linfiniti.com
Tue Jun 16 07:00:46 EDT 2009
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi Martin
Cool features you have been adding! I noticed with the node tool that if
you undo it leaves the vertex marker boxes behind and then things get a
litte loopy because the node tool lets you drag the ghost of the line
around (the line state as it was before you pressed undo).
Regards
Martin Dobias wrote:
> On Sun, Jun 14, 2009 at 6:58 PM, Giovanni
> Manghi<giovanni.manghi at gmail.com> wrote:
>>> Your comments are as always highly welcome.
>> It seems to work pretty fine. I just noticed that in point layers when
>> you add a point the stack isn't updated. This doesn't happens when you
>> move or delete a point.
> Thanks for testing! I've fixed adding new point to undo stack in r10923.
> Martin
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAko3e1cACgkQqk07qZdiYjePbgCfajo09v8lFw60e1G/CUgAftk+
ZK0AoMdS+rF/PmDO0EiNoyJi2Njhk7JV
=yDar
-----END PGP SIGNATURE-----
