[Qgis-developer] Help with Tutorial and Eclipse
Matthew Denno mgdenno at gmail.com
Sun Jun 21 08:19:27 EDT 2009
Hello List,
I am wondering if someone can help me get the C++ tutorials to compile using
Eclipse?
Here is my set up:
- Ubuntu 9.04
- QGIS version 1.0.2 standard install from the repositories
- QGIS version 1.2.0 compiled and installed to /usr/local
- Eclipse Ganymede with CDT and Qt Integration
So what I have done is:
1) Create a new Qt GUI Project, GUI Type: QMainWindow (this compiles and
runs but doesn't do anything)
2) Add /usr/include/qgis to the project includes
3) Add the following to the .pro file:
       INCLUDEPATH += /usr/include/qgis
       QT += core gui sql xml svg opengl qt3support
4) Copy and paste the tutorial code from http://blog.qgis.org/node/10 to the
automatically generated main.cpp file.
I have also tried to reference the QGIS version 1.2.0 that was compiled
locally, but no luck.
When I try to compile the project it looks like the QGIS classes are not
recognized and I get the errors below.  It looks like it is finding the *.h
files.  I suspect that it is a problem with my *.pro file.
If someone could help me out it would be greatly appreciated, even just a
point in the right direction.
----ERRORS-------------
make debug
make -f Makefile.Debug
make[1]: Entering directory `/home/matt/workspace/QGIS_Test2'
/usr/bin/uic-qt4 qgis_test2.ui -o ui_qgis_test2.h
g++ -c -pipe -g -Wall -W -D_REENTRANT -DQT_SVG_LIB -DQT_QT3SUPPORT_LIB
-DQT3_SUPPORT -DQT_SQL_LIB -DQT_XML_LIB -DQT_OPENGL_LIB -DQT_GUI_LIB
-DQT_CORE_LIB -DQT_SHARED -I/usr/share/qt4/mkspecs/linux-g++ -I.
-I/usr/include/qt4/QtCore -I/usr/include/qt4/QtGui
-I/usr/include/qt4/QtOpenGL -I/usr/include/qt4/QtXml
-I/usr/include/qt4/QtSql -I/usr/include/qt4/Qt3Support
-I/usr/include/qt4/QtSvg -I/usr/include/qt4 -I/usr/include/qgis
-I/usr/X11R6/include -Idebug -I. -o debug/main.o main.cpp
In file included from main.cpp:6:
/usr/include/qgis/qgsapplication.h:25: error: function definition does not
declare parameters
In file included from main.cpp:7:
/usr/include/qgis/qgsproviderregistry.h:39: error: function definition does
not declare parameters
In file included from /usr/include/qgis/qgsrenderer.h:29,
                 from /usr/include/qgis/qgssinglesymbolrenderer.h:22,
                 from main.cpp:8:
/usr/include/qgis/qgis.h:26: error: function definition does not declare
parameters
In file included from /usr/include/qgis/qgssinglesymbolrenderer.h:22,
                 from main.cpp:8:
/usr/include/qgis/qgsrenderer.h:39: error: function definition does not
declare parameters
In file included from main.cpp:8:
/usr/include/qgis/qgssinglesymbolrenderer.h:26: error: function definition
does not declare parameters
/usr/include/qgis/qgssinglesymbolrenderer.h:68: error:
‘QgsSingleSymbolRenderer’ has not been declared
/usr/include/qgis/qgssinglesymbolrenderer.h:68: error: non-member function
‘const QgsSymbol* symbol()’ cannot have cv-qualifier
/usr/include/qgis/qgssinglesymbolrenderer.h: In function ‘const QgsSymbol*
symbol()’:
/usr/include/qgis/qgssinglesymbolrenderer.h:70: error: ‘mSymbol’ was not
declared in this scope
/usr/include/qgis/qgssinglesymbolrenderer.h: At global scope:
/usr/include/qgis/qgssinglesymbolrenderer.h:73: error:
/usr/include/qgis/qgssinglesymbolrenderer.h:73: error: non-member function
‘bool needsAttributes()’ cannot have cv-qualifier
In file included from main.cpp:9:
/usr/include/qgis/qgsmaplayerregistry.h:35: error: function definition does
In file included from /usr/include/qgis/qgsrectangle.h:26,
                 from /usr/include/qgis/qgsmaplayer.h:27,
                 from /usr/include/qgis/qgsvectorlayer.h:28,
                 from main.cpp:10:
/usr/include/qgis/qgspoint.h:30: error: function definition does not declare
parameters
/usr/include/qgis/qgspoint.h:138: error: expected ‘,’ or ‘...’ before ‘&’
token
/usr/include/qgis/qgspoint.h:138: error: ISO C++ forbids declaration of
‘QgsPoint’ with no type
/usr/include/qgis/qgspoint.h:138: error: ‘bool operator==(int)’ must have an
argument of class or enumerated type
/usr/include/qgis/qgspoint.h:146: error: expected ‘,’ or ‘...’ before ‘&’
token
/usr/include/qgis/qgspoint.h:146: error: ISO C++ forbids declaration of
/usr/include/qgis/qgspoint.h: In function ‘std::ostream&
operator<<(std::ostream&, int)’:
/usr/include/qgis/qgspoint.h:149: error: ‘p’ was not declared in this scope
/usr/include/qgis/qgspoint.h: At global scope:
/usr/include/qgis/qgspoint.h:146: warning: unused parameter ‘QgsPoint’
In file included from /usr/include/qgis/qgsmaplayer.h:27,
                 from main.cpp:10:
/usr/include/qgis/qgsrectangle.h:35: error: function definition does not
declare parameters
/usr/include/qgis/qgsrectangle.h:134: error: expected initializer before
‘::’ token
/usr/include/qgis/qgsrectangle.h:138: error: ‘QgsRectangle’ has not been
declared
/usr/include/qgis/qgsrectangle.h: In function ‘void setXMinimum(double)’:
/usr/include/qgis/qgsrectangle.h:140: error: ‘xmin’ was not declared in this
scope
/usr/include/qgis/qgsrectangle.h: At global scope:
/usr/include/qgis/qgsrectangle.h:143: error: ‘QgsRectangle’ has not been
declared
/usr/include/qgis/qgsrectangle.h: In function ‘void setXMaximum(double)’:
/usr/include/qgis/qgsrectangle.h:145: error: ‘xmax’ was not declared in this
scope
/usr/include/qgis/qgsrectangle.h:148: error: ‘QgsRectangle’ has not been
declared
/usr/include/qgis/qgsrectangle.h: In function ‘void setYMinimum(double)’:
/usr/include/qgis/qgsrectangle.h:150: error: ‘ymin’ was not declared in this
scope
/usr/include/qgis/qgsrectangle.h:153: error: ‘QgsRectangle’ has not been
declared
/usr/include/qgis/qgsrectangle.h: In function ‘void setYMaximum(double)’:
/usr/include/qgis/qgsrectangle.h:155: error: ‘ymax’ was not declared in this
scope
/usr/include/qgis/qgsrectangle.h:158: error: ‘QgsRectangle’ has not been
declared
/usr/include/qgis/qgsrectangle.h:158: error: non-member function ‘double
xMaximum()’ cannot have cv-qualifier
/usr/include/qgis/qgsrectangle.h: In function ‘double xMaximum()’:
/usr/include/qgis/qgsrectangle.h:160: error: ‘xmax’ was not declared in this
scope
/usr/include/qgis/qgsrectangle.h:163: error: ‘QgsRectangle’ has not been
declared
/usr/include/qgis/qgsrectangle.h:163: error: non-member function ‘double
xMinimum()’ cannot have cv-qualifier
/usr/include/qgis/qgsrectangle.h: In function ‘double xMinimum()’:
/usr/include/qgis/qgsrectangle.h:165: error: ‘xmin’ was not declared in this
scope
/usr/include/qgis/qgsrectangle.h:168: error: ‘QgsRectangle’ has not been
declared
/usr/include/qgis/qgsrectangle.h:168: error: non-member function ‘double
yMaximum()’ cannot have cv-qualifier
/usr/include/qgis/qgsrectangle.h: In function ‘double yMaximum()’:
/usr/include/qgis/qgsrectangle.h:170: error: ‘ymax’ was not declared in this
scope
/usr/include/qgis/qgsrectangle.h:173: error: ‘QgsRectangle’ has not been
declared
/usr/include/qgis/qgsrectangle.h:173: error: non-member function ‘double
yMinimum()’ cannot have cv-qualifier
/usr/include/qgis/qgsrectangle.h: In function ‘double yMinimum()’:
/usr/include/qgis/qgsrectangle.h:175: error: ‘ymin’ was not declared in this
scope
/usr/include/qgis/qgsrectangle.h:178: error: ‘QgsRectangle’ has not been
declared
/usr/include/qgis/qgsrectangle.h:178: error: non-member function ‘double
width()’ cannot have cv-qualifier
/usr/include/qgis/qgsrectangle.h: In function ‘double width()’:
/usr/include/qgis/qgsrectangle.h:180: error: ‘xmax’ was not declared in this
scope
/usr/include/qgis/qgsrectangle.h:180: error: ‘xmin’ was not declared in this
scope
/usr/include/qgis/qgsrectangle.h:183: error: ‘QgsRectangle’ has not been
declared
/usr/include/qgis/qgsrectangle.h:183: error: non-member function ‘double
height()’ cannot have cv-qualifier
/usr/include/qgis/qgsrectangle.h: In function ‘double height()’:
/usr/include/qgis/qgsrectangle.h:185: error: ‘ymax’ was not declared in this
scope
/usr/include/qgis/qgsrectangle.h:185: error: ‘ymin’ was not declared in this
scope
/usr/include/qgis/qgsrectangle.h:188: error: ‘QgsPoint’ does not name a type
/usr/include/qgis/qgsrectangle.h:192: error: expected ‘,’ or ‘...’ before
‘&’ token
/usr/include/qgis/qgsrectangle.h:192: error: ISO C++ forbids declaration of
‘QgsRectangle’ with no type
/usr/include/qgis/qgsrectangle.h: In function ‘std::ostream&
/usr/include/qgis/qgsrectangle.h:192: error: redefinition of ‘std::ostream&
/usr/include/qgis/qgspoint.h:146: error: ‘std::ostream&
operator<<(std::ostream&, int)’ previously defined here
/usr/include/qgis/qgsrectangle.h:194: error: ‘r’ was not declared in this
scope
/usr/include/qgis/qgsrectangle.h:192: warning: unused parameter
‘QgsRectangle’
In file included from /usr/include/qgis/qgsvectorlayer.h:28,
                 from main.cpp:10:
/usr/include/qgis/qgsmaplayer.h:41: error: function definition does not
declare parameters
In file included from /usr/include/qgis/qgsvectorlayer.h:29,
                 from main.cpp:10:
/usr/include/qgis/qgsfeature.h:49: error: function definition does not
declare parameters
In file included from /usr/include/qgis/qgsvectorlayer.h:30,
                 from main.cpp:10:
/usr/include/qgis/qgssnapper.h:32: error: function definition does not
declare parameters
/usr/include/qgis/qgssnapper.h:58: error: function definition does not
declare parameters
In file included from /usr/include/qgis/qgsvectorlayer.h:32,
                 from main.cpp:10:
/usr/include/qgis/qgsfield.h:29: error: function definition does not declare
parameters
/usr/include/qgis/qgsfield.h:147: error: ‘QgsField’ was not declared in this
scope
/usr/include/qgis/qgsfield.h:147: error: template argument 2 is invalid
/usr/include/qgis/qgsfield.h:147: error: invalid type in declaration before
‘;’ token
In file included from main.cpp:10:
/usr/include/qgis/qgsvectorlayer.h:57: error: function definition does not
declare parameters
In file included from main.cpp:11:
/usr/include/qgis/qgsmapcanvas.h:62: error: function definition does not
declare parameters
/usr/include/qgis/qgsmapcanvas.h:93: error: function definition does not
declare parameters
main.cpp: In function ‘int main(int, char**)’:
main.cpp:22: error: ‘QgsApplication’ was not declared in this scope
main.cpp:22: error: expected `;' before ‘app’
main.cpp:30: error: ‘QgsProviderRegistry’ has not been declared
main.cpp:33: error: invalid use of incomplete type ‘struct QgsVectorLayer’
/usr/include/qgis/qgsrenderer.h:22: error: forward declaration of ‘struct
QgsVectorLayer’
main.cpp:34: error: ‘QgsSingleSymbolRenderer’ was not declared in this scope
main.cpp:34: error: ‘mypRenderer’ was not declared in this scope
main.cpp:34: error: expected type-specifier before ‘QgsSingleSymbolRenderer’
main.cpp:34: error: expected `;' before ‘QgsSingleSymbolRenderer’
main.cpp:35: error: ‘QgsMapCanvasLayer’ was not declared in this scope
main.cpp:35: error: template argument 1 is invalid
main.cpp:35: error: invalid type in declaration before ‘;’ token
main.cpp:37: error: invalid use of incomplete type ‘struct QgsVectorLayer’
QgsVectorLayer’
main.cpp:38: error: invalid use of incomplete type ‘struct QgsVectorLayer’
QgsVectorLayer’
main.cpp:48: error: ‘QgsMapLayerRegistry’ has not been declared
main.cpp:50: error: request for member ‘append’ in ‘myLayerSet’, which is of
non-class type ‘int’
main.cpp:52: error: ‘QgsMapCanvas’ was not declared in this scope
main.cpp:52: error: ‘mypMapCanvas’ was not declared in this scope
main.cpp:52: error: expected type-specifier before ‘QgsMapCanvas’
main.cpp:52: error: expected `;' before ‘QgsMapCanvas’
main.cpp:53: error: invalid use of incomplete type ‘struct QgsVectorLayer’
QgsVectorLayer’
main.cpp:63: error: ‘app’ was not declared in this scope
main.cpp: At global scope:
main.cpp:19: warning: unused parameter ‘argc’
main.cpp:19: warning: unused parameter ‘argv’
make[1]: *** [debug/main.o] Error 1
make: *** [debug] Error 2
make[1]: Leaving directory `/home/matt/workspace/QGIS_Test2'
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090621/79e99af6/attachment-0001.html
