[Qgis-developer] Raster Plugin
Paolo Cavallini cavallini at faunalia.it
Thu Mar 5 04:57:08 EST 2009
> Hi Tim,
> I think, that I was the one you mean with the gdal plugin idea (about a
> month ago). I think that a whole gdal frontend is too extensive for my
> bachelor thesis. So I just want to start with the coordinate system warp.
> Probably, I will go on developing after I finished my bachelor, but I have
> to concentrate on that small part first.
> I will plan the plugin variable, so that I can add other gdal functions
> after my bachlor thesis.
Hi Florian.
Good news you're starting work on this. Even if a whole frontend to all
GDAL functions would be too much, please consider this opportunity and try
to write your plugin in a way it could be extended with other functions.
Also, it would be good if you could open the development to others,
perhaps via svn.
All the best, and thanks!
pc
Paolo Cavallini
http://faunalia.it/pc
