[Qgis-developer] PostGisTools Plugin
Mauricio de Paulo mauricio.dev at gmail.com
Fri Mar 6 21:55:17 EST 2009
	Hi Martin.
	I'm glad to hear it. It's actually pretty easy to insert it inside
Postgis Manager as the only difference would be eliminating the
__init__.py.
	Whenever you feel like it, I can add the code to the Manager. Have you
tested the plugin itself yet?
	I think that even though the interface should be inside postgis
manager, the access to the favourites should be from the plugin toolbox.
What do you think?
	Maurício de Paulo
On Fri, 2009-03-06 at 14:30 +0100, Martin Dobias wrote:
> On Fri, Mar 6, 2009 at 3:48 AM, Mauricio de Paulo
> <mauricio.dev at gmail.com> wrote:
> > Ok, as reported yesterday I'm working on the plugin to create automated
> > gui for queries define by the users in a xml filme.
> > Today I've been able to do the first tests on this plugin. It's better
> > than I expected as it took 10 seconds to create a new "Run SQL Query"
> > plugin and another 10 seconds to create a "Count IF" plugin.
> > Well, at the moment the tool to edit the xml isn't even started (well, I
> > have the gui designed) but I wish to focus on the bugfixing of this part
> > of the plugin as we can set the tools using text files and editing the
> > xml. So if anyone could be so kind to test it a little, it's uploaded in
> > the default contributed repository.
> Hi Mauricio,
> I was wondering whether it wouldn't be more efficient to implement
> this functionality to PostGIS Manager I've developed some time ago? It
> features also SQL query window, so it could be relatively easy to add
> this as "favourite sql queries" ?
> Regards
> Martin
