AW: [Qgis-developer] SpatiaLite data provider
Alex Mandel tech_dev at wildintellect.com
Sat Mar 7 13:29:23 EST 2009
Paolo Cavallini wrote:
> Hugentobler Marco ha scritto:
>> However, we should discuss the minimum version issues of sqlite3 and
>> proj before you proceed with committing. Would it be an option to add
>> a cmake test for the sqlite version that is available, create a cmake
>> variable and build the sqlite provider if it is set? You would need
>> to consider that in providers/CMakeLists.txt and probably in the
>> opening dialog.
> Hi Alessandro.
> What minimum Sqlite version does SpatiaLite needs? In Debian it is at
> 3.5.9, which is not really old (3.6.11 now). Is this too old for SpatiaLite?
> Anyway, at least for the internal sqlite, what does prevent us from
> shipping the latest version?
> All the best.
> pc
3.5.9 works with Spatialite, but 3.6.x is required for some features to
work properly. As I mentioned before though on Ubuntu I used the package
for jaunty as a drop in replacement without a hitch.
Alex
