RE: [Qgis-developer] GSoC: GDAL/OGR frontend plugin?
Lucena, Ivan ivan.lucena at pmldnet.com
Thu Mar 12 13:36:37 EDT 2009
Hi There,
Good discussion and I hope I am not intruding.
Are you guys talking about a "Export Raster Data" dialog similar to what ArcMap has?
A UI where you can enter create-options, data-type, metadata and output-format?
That would be nice but it doesn't look like a plugin but rather a internal implementation.
Just a thought.
Regards,
Ivan
>  -------Original Message-------
>  From: Florian Hillen <fhillen at uni-osnabrueck.de>
>  Subject: RE: [Qgis-developer] GSoC: GDAL/OGR frontend plugin?
>  Sent: Mar 12 '09 16:30
>  Hi Godofredo,
>  do you mean translate a JPEG into a TIFF? Or what do you exactly mean?
>  The first function is only the reprojection between different crs, this
>  means: Select a rasterfile (e.g. epsg: 4326), choose new filename and crs
>  (e.g. epsg: 31467) and receive a new raster with the new crs.
>  All further function (gdal translate too) are also planed bit by bit ;)
>  Best regards,
>  Florian
>  > Hi Florian:
>  > Are you considering the export between formats for GDAL
>  > in your GDAL frontend?.
>  > Regards
>  > Godofredo Contreras
>  >> Date: Thu, 12 Mar 2009 14:08:14 +0100
>  >> Subject: Re: [Qgis-developer] GSoC: GDAL/OGR frontend plugin?
>  >> From: fhillen at uni-osnabrueck.de
>  >> To: qgis-developer at lists.osgeo.org
>  >> Hi Ian,
>  >> I'm currently working on a GDAL frontend. In the first step it includes
>  >> only the warp / reproject part, but it is designed to be expanded
>  >> afterwards.
>  >> I think that the ogr plugin is very intuitive, but maybe that just my
>  >> opinion ;)
>  >> Best regards,
>  >> Florian
>  >> > Hello all,
>  >> > I'm looking for a good Google Summer of Code project. Having used QGIS
>  >> and
>  >> > being a proficient Python/GIS programmer I think its the perfect fit.
>  >> I
>  >> > did
>  >> > some googling and saw that there is already some interest in a
>  >> GDAL/OGR
>  >> > front end, but I would really like to take this full on. The
>  >> OGR-converter
>  >> > plugin is not complete, as it can't do CRS transforms, and I hate to
>  >> say I
>  >> > don't find it very intuitive. Furthermore I think a lot of the
>  >> GDAL/OGR
>  >> > functionality should be able to be done "in-place" on layers, so one
>  >> could
>  >> > easily create a new layer from an existing one.
>  >> > I think unifying CRS related options could also go a long way, using
>  >> GDAL
>  >> > to
>  >> > support more than just proj4 definitions and being able to create a
>  >> custom
>  >> > CRS from any place that you can select them.
>  >> > Maybe its because my single biggest headache in learning GIS was
>  >> dealing
>  >> > with projections, and now that I understand them through the command
>  >> line
>  >> > I
>  >> > want to make it easier on others to deal with them. I think QGIS can
>  >> be
>  >> > the
>  >> > perfect tool for this because it is already great for visualization.
>  >> > Please give me your feedback on this!
>  >> > Thanks
>  >> > Ian Johnson
>  >> > _______________________________________________
>  >> > Qgis-developer mailing list
>  >> > Qgis-developer at lists.osgeo.org
>  >> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
>  > _________________________________________________________________
>  > Windows Live™: Life without walls.
>  > http://windowslive.com/explore?ocid=TXT_TAGLM_WL_allup_1a_explore_032009
