[Qgis-developer] GSoC: GDAL/OGR frontend plugin?
Florian Hillen
fhillen at uni-osnabrueck.de
Tue Mar 17 11:18:36 EDT 2009
Hi Godofredo,
I'm not working with python. So I can't help you with your problem, sorry.
gdal translate would be a nice addition to the gdal plugin, but I'm coding
in c++. It would be great if we can merge our plugins in any way. Does
anybody has an idea for that?
Best regards,
Florian
> Hi Florian and Ivan:
> Sorry for my late reply, I meant a raster dialog to wrap the funtionality
> of gdal_translate. For example choose a raster file, select a new file, an
> output format and the creation options to export from gtiff to ecw,
> jpg2000 or any other format available in gdal. An example of such dialog
> is the openev export tool.
> The openev export tool is written in python and I tried to create a python
> plugin borrowing the code but I couldn't make the progress callback of
> gdalcreatecopy work. I always got a runtime error saying "object passed
> is not a python function". Florian if you are working with python have you
> faced this problem?
> I can think in a class like QgsVectorFileWriter for rasters to enable a
> "save as" option to export the currently selected raster layer in legend
> to any gdal enabled format.
> Also if you are doing something similar I would like to join efforts
> instead
> of replicating work.
> Regards
> Godofredo Contreras
>> From: ivan.lucena at pmldnet.com
>> To: fhillen at uni-osnabrueck.de; qgis-developer at lists.osgeo.org
>> Subject: RE: [Qgis-developer] GSoC: GDAL/OGR frontend plugin?
>> Date: Thu, 12 Mar 2009 17:36:37 +0000
>> CC:
>> Hi There,
>> Good discussion and I hope I am not intruding.
>> Are you guys talking about a "Export Raster Data" dialog similar to what
>> ArcMap has?
>> A UI where you can enter create-options, data-type, metadata and
>> output-format?
>> That would be nice but it doesn't look like a plugin but rather a
>> internal implementation.
>> Just a thought.
>> Regards,
>> Ivan
>> > -------Original Message-------
>> > From: Florian Hillen <fhillen at uni-osnabrueck.de>
>> > Sent: Mar 12 '09 16:30
>> > Hi Godofredo,
>> > do you mean translate a JPEG into a TIFF? Or what do you exactly
>> mean?
>> > The first function is only the reprojection between different crs,
>> this
>> > means: Select a rasterfile (e.g. epsg: 4326), choose new filename and
>> crs
>> > (e.g. epsg: 31467) and receive a new raster with the new crs.
>> > All further function (gdal translate too) are also planed bit by bit
>> > Best regards,
>> > Florian
>> > > Hi Florian:
>> > > Are you considering the export between formats for GDAL
>> > > in your GDAL frontend?.
>> > > Regards
>> > > Godofredo Contreras
>> > >> Date: Thu, 12 Mar 2009 14:08:14 +0100
>> > >> Subject: Re: [Qgis-developer] GSoC: GDAL/OGR frontend plugin?
>> > >> From: fhillen at uni-osnabrueck.de
>> > >> To: qgis-developer at lists.osgeo.org
>> > >> Hi Ian,
>> > >> I'm currently working on a GDAL frontend. In the first step it
>> includes
>> > >> only the warp / reproject part, but it is designed to be expanded
>> > >> afterwards.
>> > >> I think that the ogr plugin is very intuitive, but maybe that just
>> my
>> > >> opinion ;)
>> > >> Best regards,
>> > >> Florian
>> > >> > Hello all,
>> > >> > I'm looking for a good Google Summer of Code project. Having
>> used QGIS
>> > >> and
>> > >> > being a proficient Python/GIS programmer I think its the perfect
>> fit.
>> > >> I
>> > >> > did
>> > >> > some googling and saw that there is already some interest in a
>> > >> GDAL/OGR
>> > >> > front end, but I would really like to take this full on. The
>> > >> OGR-converter
>> > >> > plugin is not complete, as it can't do CRS transforms, and I
>> hate to
>> > >> say I
>> > >> > don't find it very intuitive. Furthermore I think a lot of the
>> > >> GDAL/OGR
>> > >> > functionality should be able to be done "in-place" on layers, so
>> one
>> > >> could
>> > >> > easily create a new layer from an existing one.
>> > >> > I think unifying CRS related options could also go a long way,
>> using
>> > >> GDAL
>> > >> > to
>> > >> > support more than just proj4 definitions and being able to
>> create a
>> > >> custom
>> > >> > CRS from any place that you can select them.
>> > >> > Maybe its because my single biggest headache in learning GIS was
>> > >> dealing
>> > >> > with projections, and now that I understand them through the
>> command
>> > >> line
>> > >> > I
>> > >> > want to make it easier on others to deal with them. I think QGIS
>> can
>> > >> be
>> > >> > the
>> > >> > perfect tool for this because it is already great for
>> visualization.
>> > >> > Please give me your feedback on this!
>> > >> > Thanks
>> > >> > Ian Johnson
>> > >> > _______________________________________________
>> > >> > Qgis-developer mailing list
>> > >> > Qgis-developer at lists.osgeo.org
>> > >> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > > _________________________________________________________________
>> > > Windows Live™: Life without walls.
>> > > http://windowslive.com/explore?ocid=TXT_TAGLM_WL_allup_1a_explore_032009
> Hotmail® is up to 70% faster. Now good news travels really fast.
> http://windowslive.com/online/hotmail?ocid=TXT_TAGLM_WL_HM_70faster_032009
