[Qgis-developer] GDAL warp problem
Florian Hillen fhillen at uni-osnabrueck.de
Wed Mar 18 05:40:02 EDT 2009
Hi list,
I found a warp tutorial [1] for a simple reprojection yesterday, but it
doesn't work as it should.
The code creates a new GTiff with a new coordinate system, but the warp
seems to fail, because the coordinates are the same as in the origin. The
function GDALSuggestedWarpOutput already calculates the wrong output size,
so I think the error must be somewhere around the function
GDALCreateGenImgProjTransformer. If I warp the image with console-based
gdalwarp (gdalwarp -s_srs epsg:31467 -t_srs epsg:4326 src dst) everything
works out fine.
I read somewhere in the web, that it might caused by a wrong path to the
gdal or proj libary, but I tried both dll paths (msys\bin and msys\lib).
Does anyone of you can support me in that?
Best regards,
Florian
[1] http://www.gdal.org/warptut.html
