[Qgis-developer] build qgis-grass plugin on Windows
G. Allegri giohappy at gmail.com
Wed Mar 18 14:36:46 EDT 2009
Hi Godofredo,
thanks for your hints. I'll tru it as soon as possible. In the meanwhile
could you help me to clarify some other related aspects?
 1 - how were the various libs you listed built? VS or MinGW. AFAIK they're
used both from Grass and QGIS, am I wrong? I thought that Grass couldn't use
libs built with VS...
 2 - this is the qgis ml but do you know how grass was built (osgeo4w
msys+mnigw would be ok?) and, related to the previous question, against
which libs?
Thanks very much for helping to dig in the Windows world :)
giovanni
2009/3/18 godofredo contreras <frdcn at hotmail.com>
>  Hi Giovanny:
> You can use the libs and includes bundled with osgeo4w to build qgis and
> grass plugin.
> Using osgeo4w do the following:
> install grass from desktop category
> install grass-devel-vc from libs (be sure is the same version that grass )
> install gdal from libs
> install geos from libs
> install sqlite from libs
> install proj from libs
> install xpat from libs
> install gsl from libs
> create the environment variable LIB_DIR pointing to c:/osgeo4w and run
> cmakesetup, after that set GRASS_PREFIX to the grass instalation directory
> (something like c:/osgeo4w/apps/grass/gras-6.4.0R3)
> And thats all, start compiling with visual studio or nmake
> Hope this helps
> Regards
> Godofredo Contreras
> Date: Wed, 18 Mar 2009 17:42:13 +0100
> From: giohappy at gmail.com
> To: qgis-developer at lists.osgeo.org
> Subject: [Qgis-developer] build qgis-grass plugin on Windows
> Hi. I'm going on with my battle to compile qgis+grass on windows vista...
> very frustrating!
> I've almost finished to compile grass under mingw, as AFAIK it's the only
> way to do it. Am I wrong?
> I've built its various dependencies (like GDAL, proj, libtiff, freetype,
> etc.) under ingw too.
> Now, what to do with QGIS? I know it should be compiled with MSVC, at least
> it's the way choosen for OSGeo4W stack. So I should rebuild GDAL, and all
> the rest of the stuff, with MSVC? And, at the end, how to build the
> grass-qgis plugin? Isn't it a problem having compiled the various parts with
> different systems?
> Ok, I admit, I'm a bit confused working on Windos. Linux is more linear to
> me! :)
> Giovanni
> Windows Live™ Contacts: Organize your contact list. Check it out.<http://windowslive.com/connect/post/marcusatmicrosoft.spaces.live.com-Blog-cns%21503D1D86EBB2B53C%212285.entry?ocid=TXT_TAGLM_WL_UGC_Contacts_032009>
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090318/66788417/attachment.html
