[Qgis-developer] Improvements to open vector dialog
godofredo contreras
frdcn at hotmail.com
Fri Mar 20 17:49:15 EDT 2009
> Date: Wed, 18 Mar 2009 14:09:38 +0100
> From: cavallini at faunalia.it
> To: frdcn at hotmail.com
> CC: qgis-developer at lists.osgeo.org
> Subject: Re: [Qgis-developer] Improvements to open vector dialog
> godofredo contreras ha scritto:
> > I have been working in a patch for open vector layer dialog to improve
> > it and extend it to support database, protocol and directory
> > connections in addition to the already implemented file support.
> Hi Godofredo:
> I'm playing with your improvement, which I find quite useful. Most
> layers (GRASS and PostGIS) could be loaded without fuss, but one
> specific GRASS vector among those I tried causes QGIS to crash without
> any warning on the command line. The same layer, opened from the grass
> plugin, says:
> No layers available in this map
> So obviously the plugin is more robust than OGR access.
> I'm attaching it here for further testing if you're interested.
> Paolo Cavallini: http://www.faunalia.it/pc
Hi Paolo:
Thank you for the feedback, I will test it and try to fix the problem if it
is ogr provider specific or post a bug in gdal/ogr trac.
Regards
Godofredo Contreras
_________________________________________________________________
Internet Explorer 8 – Now Available. Faster, safer, easier.
http://clk.atdmt.com/MRT/go/141323790/direct/01/
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090320/7b019354/attachment.html
