[Qgis-developer] custom prj
Martin Dobias wonder.sk at gmail.com
Mon Mar 23 08:29:14 EDT 2009
On Mon, Mar 23, 2009 at 11:50 AM, francesco marucci
<francesco.marucci at gmail.com> wrote:
> then qGis calls this layer with this request:
> ?REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&LAYERS=158_UTMA_ORTOAGEA2008&STYLES=&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SRS=CRS:84&BBOX=9.1600714390999993,43.672498615800002,12.9109804049,45.156071086600001&FORMAT=image/jpeg&WIDTH=640&HEIGHT=373
> It seems that qGis is not recognizing the EPSG:NONE, while with others
> WMS clients (ArcMap, Gaia, uDig, GvSig) this layer is requested
> calling the EPSG:NONE and it is visualized correctly.
This is somewhat unrelated to the original problem...
I suggest you to put it into Trac and someone will likely fix it :)
Martin
