[Qgis-developer] build qgis-grass plugin on Windows
G. Allegri giohappy at gmail.com
Mon Mar 23 16:02:31 EDT 2009
Wow Godofredo, thanks a lot. This sed script is something magic to me! :)
Does the QGis build chain permit to build only the grass-plugin?
So many questions, I'm sorry, but thi are my very first steps to
compile in the Microsoft env!
2009/3/23 godofredo contreras <frdcn at hotmail.com>:
> If you built your own grass then you can create your msvc import libraries:
> Copy and save the following sed script to mkdef.sed in the directory
> where your grass dlls are located.
> /Dump of file / {
> s/Dump of file \([^ ]*\)$/LIBRARY \1/p
> a\
> EXPORTS
> /[ ]*ordinal hint/,/^[ ]*Summary/ {
> /^[ ]\+[0-9]\+/ {
> s/^[ ]\+[0-9]\+[ ]\+[0-9A-Fa-f]\+[ ]\+[0-9A-Fa-f]\+[ ]\+\([^ =]\+\).*$/ \1/p
> Download and install sed utility from:
> http://gnuwin32.sourceforge.net/packages/sed.htm
> Make sure sed directory is in the environment variable path
> Open Visual Studio C++ command line.
> change working directory to the directory where your grass dlls are located
> Execute the following commands for every grass dll ({grassdll} must be
> changed to
> grass dll name) :
> dumpbin /exports {grassdll} | sed -nf mkdef.sed > {grassdll}.def
> lib /def:{grassdll}.def /machine:x86
> Those commands will create {grassdll}.lib that you can use with
> visual studio.
> Regards
> Godofredo Contreras
>> Date: Fri, 20 Mar 2009 20:01:39 +0100
>> Subject: Re: [Qgis-developer] build qgis-grass plugin on Windows
>> From: giohappy at gmail.com
>> To: frdcn at hotmail.com
>> CC: qgis-developer at lists.osgeo.org
>> > install grass-devel-vc from libs (be sure is the same version that grass
>> This is the problem! I need to recompile qgis-grass plugin for a newer
>> version of grass... I wanted to try Marco Pasetti's way [1], but I'm
>> not sure how and if it's possible to be integrated in the osgeo4w qgis
>> cinfiguration.
>> [1] http://www.webalice.it/marco.pasetti/qgis+grass/BuildFromSource.html
> ________________________________
> Internet Explorer 8 – Now Available. Faster, safer, easier. Download FREE
> now!
