[Qgis-developer] Data for QGIS Hackfest
Tim Sutton lists at linfiniti.com
Thu Mar 26 16:43:25 EDT 2009
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Maciej Sieczka wrote:
> Andreas Neumann pisze:
>> I'd like the mention that the display of very large rasters is
>> normally not a problem if you used gdaladdo to add pyramids to your
>> data. You can use rasters with the hundreds of gigs of filesize
>> without a bottleneck. You'd have to build the pyramids however. If
>> you store your data in multiple files instead of just one, you should
>> build a tileindex with gdaltindex. See
>> http://www.gdal.org/gdal_utilities.html for more infos.
QGIS doesnt (that I know of) work with tile indexes but you can create a
gdal .vrt virtual dataset from a bunch of files (using gdalbuildvrt.py).
You can also build pyramids on the virtual dataset and I have found
performance to be reasonable once zoomed in a little on a ~1TB test dataset.
Regards
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAknL6O0ACgkQqk07qZdiYjdRcACcDQTvgsYuRaMpHB12DxSuTasC
tIMAn3m8mF+ipL36CStaDnmQtWbRcyJy
=Ri2T
-----END PGP SIGNATURE-----
