[Qgis-developer] Re: manageR 0.6.2 error
Maciej Sieczka msieczka at sieczka.org
Tue Mar 31 11:53:47 EDT 2009
Carson Farmer pisze:
> oops, didn't reply all on this one... sorry Maciej if you get this twice:
>>> There's an erorr at manageR 0.6.2 error instalation in QGIS trunk
>>> r10438:
>>> __init__() takes exactly 2 arguments (3 given)
>> This isn't an error with manageR /per se/, the plugin has actually
>> been installed properly, but you have to restart qgis before it will
>> work properly. This is a problem with the plugin installer, and Borys
>> is aware of it... but there is currently no work around. In any case,
>> if you installed manageR, it should be working fine when you restart
>> (assuming rpy2 and numpy and R are properly installed ;-) )
OK. Thanks for explaining.
Maciek
Maciej Sieczka
http://www.sieczka.org
