[Qgis-developer] python: which symbol for classified feature
Richard Duivenvoorde rdmailings at duif.net
Sat May 9 14:21:09 EDT 2009
Martin Dobias wrote:
> Hi Richard,
> you might want to call renderer's renderFeature() method. This method
> prepares painter for drawing of the feature based on the geometry
> type:
> - line - sets painter's pen
> - polygon - sets painter's pen and brush
> - point - modifies a QImage instance passed as an argument (will
> contain the marker)
> I'm not sure whether it will work with point symbols in python, the
> interface is somehow messy. But for lines and polygons you should be
> able to get the information you want from painter.
> Bye
> Martin
Thanks for your answer Martin. But I wasn't able to get any info from
the painter after calling the renderFeature(..) method...
So what I did now (and is working :-) ): is actually copy the
functionality of the symbolForFeature(feature) method to my plugin in
python: after rendering a renderer holds a list of 'symbols' which not
only hold the symbolic-info, but also the lower- and  upperborder (if
availble). So given the value of a feature I can determine myself which
symbol is used for it (just like the implementation of symbolForFeature.
Regards,
