[Qgis-developer] 1.1 and 1.0.1 Release plans & feature freeze
Otto Dassau otto.dassau at gmx.de
Tue May 12 01:49:52 EDT 2009
On Sat, 9 May 2009 16:51:54 +0200
Martin Dobias <wonder.sk at gmail.com> wrote:
> On Fri, May 8, 2009 at 1:37 PM, Carson Farmer <carson.farmer at gmail.com> wrote:
> > Otto et al.,
> > I very much like this idea. Some of my own thoughts:
> > Another possible set of tags: [NEW FEATURE], [BUG FIX], or [UPDATE].
> > That way the developer doesn't have to decide on their own if the change
> > need to be added to the manual. Manual writers can simply decide if the NEW
> > FEATURE needs to be added or not... I also think that NEW FEATURE is more
> > intuitive for developers than MANUAL which is likely not something they are
> > thinking about at the time...
> [Manual] seems to me too broad term. On the other hand, is there any
> need for [bug fix] tag?
no there is no need for a [bug fix] tag, I think.
> Usually it's clear from the commit message :-)
> I would vote for [FEATURE] and [UPDATE]. But still I'm not sure what
> should be considered as an update... (any thoughts of examples what is
> and what is not an update?)
Probably with [UPDATE] Carson means anything that is not a new feature but
should be mentioned. Maybe something like icon changes or ?.
> Anyway, it will probably need some time to get used to any tagging...
> developers are lazy, otherwise they wouldn't have became developers
We should be keep it simple. We don't want developers to spend any (much) time
to think about what tag to use. If you are ok with [FEATURE] and [UPDATE] it
would be fine for us and very helpful! All we need is a simple hint we can grep
from the svn commit logs so we don't miss anything.
regards,
 Otto
> Martin
