Fwd: [Qgis-developer] Composer grid issue
John C. Tull
jctull at gmail.com
Wed Nov 4 15:15:18 EST 2009
William,
I was wondering if you have seen the problem with the new composer
breaking some core OS X functionality? If I open an existing project
(possibly true with new projects as well), the dock is killed, command-
tab to switch between applications does not function, expose and
spaces are non-functional, and I have to logout to cure my ails.
Have you built and tested the new composer at all? I'm trying to see
if this might be narrowed down to my use of the qt-4.6-cocoa beta or
if it is something internal to the new composer changes irrespective
of the qt version.
If you could test the current trunk, that would be useful. I just
built the xcode project, and the same problem exists as with the cmake
build.
Thanks,
John
Begin forwarded message:
> From: "John C. Tull" <jctull at gmail.com>
> Date: October 30, 2009 10:42:30 AM PDT
> To: Marco Hugentobler <marco at hugis.net>
> Cc: qgis-developer at lists.osgeo.org
> Subject: Re: [Qgis-developer] Composer grid issue
> Marco,
> On Oct 30, 2009, at 3:22 AM, Marco Hugentobler wrote:
>>> For some reason, my old project now crashes if I try to open in
>>> qgis.
>>> I suspect this might be from changes in the composer structure for
>>> qgs
>>> files, but not certain.
>> Oh, this should not happen. Project reading should be backwards
>> compatible.
>> Unfortunately, it does not crash with my test projects. Could you
>> send me the
>> project file for testing?
> The crashing issue may be specific to that project, perhaps a
> symbology issue. I was able to open several other project files
> without crashing, but a new and more serious issue has arisen. Now,
> opening the a project brings a map composer window to the screen as
> well as the canvas. This composer window cannot be minimized or
> closed. Worse, it causes Mac OS X Finder, Dock, and Spaces to all
> cease functioning. Essentially, it paralyzes the OS X gui. Quitting
> qgis does not fix this. The only solution I have found is to logout
> and log back in to restore gui functionality.
> I should add that I am using qt-4.6-beta, so it would be great if
> another Mac user with a more conservative qt environment could test
> this and see if it happens for them. The key is having an existing
> qgis project.
> Beyond that, I do not have much information to provide that may help
> uncover this. We can try to work on this off-list if you would like.
> Regards,
> John
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20091104/59b9147b/attachment-0001.html
