[Qgis-developer] Re: [GRASS-dev] error creating a GRASS location
Paolo Cavallini cavallini at faunalia.it
Thu Nov 5 03:20:18 EST 2009
On Wed, 4 Nov 2009 20:56:54 +0100, Markus Neteler <neteler at osgeo.org>
wrote:
> On Wed, Nov 4, 2009 at 5:24 PM, Paolo Cavallini <cavallini at faunalia.it>
> wrote:
>> - a space in the path prevented r.contour from running successfully
> ... I have tried that on Linux with 6.4.0svn (current), no problem.
> Which OS did you use there? The Ubuntu 9.04 GNU/Linux on the stick?
the stick, with qgis 1.4 self compiled 10 days ago.
>> Warning: QMetaObject::connectSlotsByName: No matching signal for
>> on_btnHelp_clicked()
>> terminate called after throwing an instance of 'QgsGrass::Exception'
>> what():  region for current mapset is not set
>> run "g.region"
>> Aborted
> I see the same error here:
> http://forum.qgis.org/viewtopic.php?f=2&t=5019#p8664
> http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=549120
> https://trac.osgeo.org/qgis/ticket/1964
> -> set by pcav to invalid :)
> Perhaps GRASS is crashing only subsequently?
The error seems different to me:
what(): Incompatible library version for module. You need to rebuild GRASS
or untangle multiple installations.
> Is this right:
> - which GRASS version: GRASS 6.4Rc5?
yes
> - which operating system: Ubuntu 9.04 GNU/Linux?
yes, as above.
Thanks.
http://faunalia.it/pc
