[Qgis-developer] lost QGIS_SVN_VERSION information when using Debian pbuilder
Jürgen E. Fischer jef at norbit.de
Fri Nov 13 11:51:15 EST 2009
Hi Ivan,
On Fri, 13. Nov 2009 at 16:55:32 +0100, Ivan Mincik wrote:
> I am not very familiar with cmake. Where can I look for ?
http://trac.osgeo.org/qgis/browser/trunk/qgis/CMakeLists.txt#L342
When cmake sees a .svn in the source directory it tries to
determine the checked out revision of the sources.
The easy solution proabably is to add svnversion to your pbuilder environment.
Another option is to introduce subversion as build dependency, although
released versions won't need it.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
