[Qgis-developer] Xcode project build
William Kyngesburye woklist at kyngchaos.com
Wed Nov 18 15:47:32 EST 2009
Massimo is having the same problem.  I haven't installed Qt 4.6, so I can only guess at the problem.  It appears that libQtUiTools does exist, so I wonder if it has the right architectures?
file /usr/lib/libQtUiTools.a
if only 32bit, then either nokia messed up their distribution, or they didn't intend libQtUiTools (and maybe also libQtCLucene) to be linked into end-user binaries.
On Nov 18, 2009, at 2:35 PM, John C. Tull wrote:
> Hi William,
> I tried building trunk the past several days, and have run into the following problem on each try. My latest setup is Snow Leopard with all your recent frameworks, Qt-4.6.0-cocoa, sip 4.9.2 (dev snapshot) and pyqt 4.6.2 (dev snapshot). Here is the relevant portion of the build dump (I used xcodebuild from the Terminal):
> ld: library not found for -lQtUiTools
> collect2: ld returned 1 exit status
> Command /usr/bin/g++ failed with exit code 1
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian]  What are you supposed to do WITH a maniacally depressed robot?
[Marvin]  You think you have problems?  What are you supposed to do if you ARE a maniacally depressed robot?  No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
