[Qgis-developer] Re: New composer draw shapes
Marco Hugentobler marco at hugis.net
Fri Nov 20 04:51:35 EST 2009
Hi John and list
Thanks for testing the new feature.
> >2) The Background
> > color options do not appear to do anything for me, so perhaps need to be
> > removed from the ui, or made functional assuming there is an interest for
> > a background fill behind an ellipse or triangle.
True, the non-functional background color and transparency is a bug. Should be
fixed in r12204
For uniformity of item handling, I'd like to leave the background / frame
options for composer shapes. It could however be an option that they are
transparent white by default.
> > 4) It would be ideal if the user could set opacity for the shape outline
> > and/or fill.
Agreed. I'm going to add that soon. Also I'm planning to make an item for
arrows in composer soon.
Regards,
Marco
Am Donnerstag, 19. November 2009 19.02:40 schrieb John C. Tull:
> On a similar vein, the new rotation options are very useful also. Perhaps a
>  rotation option could be added for legend items also?
> Cheers,
> John
> On Nov 19, 2009, at 9:18 AM, John C. Tull wrote:
> > Marco,
> > You've been reading my mind. I was thinking of this exact feature
> > yesterday. Thanks for adding this quite helpful function to the
> > ever-improving composer!
> > A couple of quick comments:
> > 1) The Shape outline color and shape fill color are redundant with the
> > Frame color and Background color options if using a rectangle fill. Are
> > the frame and background color options needed at all? 2) The Background
> > a background fill behind an ellipse or triangle. 3) The opacity setting
> > is non-functional.
> > and/or fill.
> > Thanks,
> > John
Dr. Marco Hugentobler
HUGIS - GIS programming and consulting
Webereistrasse 66
CH-8134 Adliswil
marco at hugis.net
http://homepage.hispeed.ch/hugis
Technical Advisor QGIS Project Steering Committee
