[Qgis-developer] segfault python: no catch for QgsException?
Richard Duivenvoorde rdmailings at duif.net
Sat Nov 21 13:52:15 EST 2009
Hi devs,
in the mapserverexport plugin we want the user to be able to load
another project into QGIS to export:
qgisProjectFile = QFileDialog.getOpenFileName(self.dlg, "Choose a
QGIS 			Project", ".", "QGIS Project Files (*.qgs);", "...")
     try:
       QgsProject.instance().read(QFileInfo(qgisProjectFile))
     #except QgsException, err:
     except:
       QMessageBox.information(self.dlg, "Not a valid QGIS projectfile.")
       return
While we do filter the view on *.qgs files, it's still possible that the
user just fills in an excisting NON-qgs-project file.
On the 'read'-call of this (off course) wrong file, qgis halts fiercely
with:
terminate called after throwing an instance of 'QgsException'
   what():  Project file read error: error occurred while parsing
element at line 1 column 1 for file /home/richard/temp/foo.jpg
Aborted
Questions:
- neither the "except QgsException:" nor 'except:" seem to catch the
exception? Doing someting wrong there? Missing Python interface?
- Isn't it possible to catch this exception? (doing exact the same thing
via the normal (non python way) 'open project'-dialog, the exception is
caught: "Project file read error: error occurred while parsing element
at line 1 column 1 for file /home/richard/temp/foo.jpg"
- shouldn't we load qgs-projects via the python interface? (for valid
qgs-files it's working ...).
- one option would be to disable the possibility of setting the path by
keyboard in QFileDialog, but I have to find out how to do that ...
All on QGIS trunk on ubuntu
Regards,
