[Qgis-developer] Ready: QGIS callout labels with screenshots, source and test project. Martin, you will get it?
Mailing Lists lists at linfiniti.com
Sun Nov 29 14:35:57 EST 2009
Hi (also for 'Ttestt')
On Sun, Nov 29, 2009 at 7:45 PM, Martin Dobias <wonder.sk at gmail.com> wrote:
> On Wed, Nov 25, 2009 at 7:15 AM, ttestt <adygtfi at gmail.com> wrote:
>> I've made some changes to have callout labels with traditional(old) labels
>> engine.
>> This is very useful to prepare printable nice looking maps.
>> I think this code will be useful.
>> I think there is a tool to move labels needed (tool will write label's
>> position to an attribute table's fields) to make work with labels more
>> comfortable. But, maybe, some will advise more powerful solution.
I could add that the CODING document in the root of your source tree
describes how one should submit a patch:
2.6. Submitting Patches
In general you should read that whole document and especially the
'2.6.5. Due Diligence' section,
I look forward to seeing your patch make its way into the code base!
Regards
Tim
> Hi "Ttestt"
> In the attached archive I've found a project file, sample data and
> modified QgsLabel class. This is not really developer friendly format.
> To make a proper patch, I would suggest you to use 'svn diff' command
> to create a patch file that contains only the changes (and not the
> whole files). Then create a new ticket in QGIS Trac and attach the
> patch. Like that, the proposed changes will not get lost in mailing
> list archive and someone will be able review the changes and possibly
> apply them to the repository.
> >From a very brief look I see you haven't done any changes to GUI, so
> how would people enable/disable the functionality?
> Please proceed with creation of a ticket in Trac. The following is an
> example of a patch contributed by community and later applied to qgis
> sources:
> http://trac.osgeo.org/qgis/ticket/1478
> Regards
> Martin
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
