[Qgis-developer] QGis & Python
Pierre Cauhopé
pierre.cauhope at free.fr
Mon Nov 30 14:12:05 EST 2009
Hi German,
Thank you for your help but unforntunatly it don't work better. Here is my
code :
# Import main libs
> import os
> from PyQt4 import QtCore, QtGui
> import sys
> from qgis.core import *
> from qgis.gui import *
Here is my error:
> File "C:\Users\Pierre\Desktop\Projet SIG\MontBlanc\qgismt\__main__.py",
> line 5, in <module>
> ImportError: DLL load failed: Le module spécifié est introuvable.
And here my systeme variables :
*Path*:
> C:\Python26;C:\qgis\bin;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;C:\Program
> Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files
> (x86)\Common Files\Adobe\AGL;C:\Program Files\TortoiseSVN\bin
> *PYTHONPATH*: C:\qgis\python
It's very strange, someone have an idea to solve this problem ?
Thank you again
Pierre
2009/11/30 Germán Carrillo <carrillo.german at gmail.com>
> Hi Pierre.
> On Windows I run a .bat file with this three lines:
> *set PYTHONPATH=c:\qgis\python
> set PATH=c:\qgis\bin;%PATH%
> set PATH=c:\Python25;%PATH%*
> After that I'm able to run PyQGIS applications. I use the QGIS standalone
> installer.
> Regards.
> Germán.
> 2009/11/30 Luca Mandolesi <mandoluca at gmail.com>
>> Sorry, but I'm working under mac os x, and the sys.path method works fine.
>> I've installed under Win the Osgeo version, but I cannot find the qgis.core,
>> only the C:/Osgeo/app/qgis/python/qgis/ folder, which contains only
>> qgis_core.pyd and qgis_gui.pyd.
>> Mmmmm! I don't understand as you can solve, but I'll try in other way!
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> |\__
> (:>__)(
> Soluciones Geoinformáticas Libres
> http://geotux.tuxfamily.org/
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20091130/fa0a1d30/attachment.html
