[Qgis-developer] Re: [Qgis-user] Value Tool Plug-in Problem
John C. Tull jctull at gmail.com
Fri Oct 2 15:23:17 EDT 2009
Thanks for that clarification, William. I was unaware of that.
My build instructions were based on using your frameworks and my own
trunk build of qgis. Do you have any suggestions on getting the plug-
in working with your binary? Apparently something is not being picked
up if the plugin is reporting qwt as missing for people.
John
On Oct 2, 2009, at 11:45 AM, William Kyngesburye wrote:
> On Oct 2, 2009, at 12:46 PM, John C.Tull wrote:
>> The gdal and osgeo modules are part of William's gdal framework, so
>> make sure those are installed on your system. The value tool plugin
>> requires pyqwt5 as well.
> Note: my Qgis binaries include a bundled pyqwt5.  I do this because
> they are meant to be installed inside the PyQt folder, it wouldn't
> work to install PyQwt5 in your system site-packages.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "This is a question about the past, is it? ... How can I tell that
> the past isn't a fiction designed to account for the discrepancy
> between my immediate physical sensations and my state of mind?"
> - The Ruler of the Universe
