[Qgis-developer] Re: [Qgis-user] Value Tool Plug-in Problem
John C. Tull
jctull at gmail.com
Fri Oct 2 18:44:53 EDT 2009
Help? Not sure. Depends on whether there is a website or not, etc.
Some are documented in the help documentation.
If you load a raster (any raster), enable the plugin (there should be
a panel, as you mentioned), then tick the second box (Value/Graph), an
interactive graph should show up. If qwt is not being picked up, then
it will say qwt not found, or similar.
Agus: are your students using the most current binary?
Regards,
John
On Oct 2, 2009, at 12:46 PM, William Kyngesburye wrote:
> When is it failing? I installed it in my current Qgis 1.3 and
> enabled it, no problems so far. I see the panel, but I have no clue
> on how it works (do plugins have help?).
> On Oct 2, 2009, at 2:23 PM, John C. Tull wrote:
>> Thanks for that clarification, William. I was unaware of that.
>> My build instructions were based on using your frameworks and my
>> own trunk build of qgis. Do you have any suggestions on getting the
>> plug-in working with your binary? Apparently something is not being
>> picked up if the plugin is reporting qwt as missing for people.
>> John
>> On Oct 2, 2009, at 11:45 AM, William Kyngesburye wrote:
>>> On Oct 2, 2009, at 12:46 PM, John C.Tull wrote:
>>>> The gdal and osgeo modules are part of William's gdal framework,
>>>> so make sure those are installed on your system. The value tool
>>>> plugin requires pyqwt5 as well.
>>> Note: my Qgis binaries include a bundled pyqwt5. I do this
>>> because they are meant to be installed inside the PyQt folder, it
>>> wouldn't work to install PyQwt5 in your system site-packages.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> Theory of the Universe
> There is a theory which states that if ever anyone discovers exactly
> what the universe is for and why it is here, it will instantly
> disappear and be replaced by something even more bizarrely
> inexplicable. There is another theory which states that this has
> already happened.
> -Hitchhiker's Guide to the Galaxy 2nd season intro
