[Qgis-developer] interpolation
Paolo Cavallini cavallini at faunalia.it
Wed Oct 7 08:05:40 EDT 2009
Marco Hugentobler ha scritto:
> Hi Paolo
> Which algorithms did you use? Afaik, the inverse distance weighting is the
> only method that is common to interpolation plugin and GDAL. And there it is
> important that you set the same distance weighting coefficient for both.
Yes, it's IDW. I used defalut parameters in both cases.
But as I said the differences were quite small (sooner or later I'll check with GRASS
algebra).
All the best.
Paolo Cavallini: http://www.faunalia.it/pc
