[Qgis-developer] Field Calculator Problem
Marco Hugentobler
marco at hugis.net
Fri Oct 30 16:26:27 EDT 2009
Hi Darren
Thanks for reporting. I filled a ticket
(http://trac.osgeo.org/qgis/ticket/2044).
As soon as I commit the changes to disk, the values seem to be normal again.
Also the identify tool shows correct results. Probably an issue with the
attribute table and not-commited values.
Regards,
Marco
Am Freitag, 30. Oktober 2009 19.38:08 schrieb Darren Cope:
> Hi all,
> I've come across a problem with the field calculator. I'm using QGIS
> 1.4.0.39 via OSGEO4W on an XP box. Here's the issue:
> When using field calculator to "Only Update Selected Features," all
> _unselected_ features (incorrectly) get a value filled. For example, if I
> create a new field, and set it equal to an existing field, the selected
> features get updated properly. However, all other features get the value of
> the first selected feature.
> Cheers,
> Darren Cope
> http://dmcope.freeshell.org
Dr. Marco Hugentobler
HUGIS - GIS programming and consulting
Honrainweg 5
CH-8038 Zürich
marco at hugis.net
http://homepage.hispeed.ch/hugis/
