[Qgis-developer] Binary QGIS 1.2.0.2~jaunty + GRASS does not work
Agustin Lobo alobolistas at gmail.com
Fri Sep 11 05:56:33 EDT 2009
After upgrading to QGIS 1.2.0.2~jaunty, the python grass
plugin still installs libgdal1-1.5.0 (+ grass 6.4.0~rc5-2~jaunty)
and QGIS crashes upon start up with message:
"Uncatched fatal GRASS error. Incompatible library version for module.
You need to rebuild GRASS or untangle multiple installations"
Removing libgdal1-1.6.0  does not solve the problem
Removing libgdal1-1.5.0  (now you can do it without automatic uninstal
of the grass plugin) and installing libgdal1-1.6.0  does not solve the
problem either.
Grass runs fine independently in all cases.
Qgis runs fine without the grass plugin
Agus
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090911/289d6f9a/alobolistas.vcf
